  3. Home Assistant
  4. Home Assistent + Serial Gateway + Motion Sensor
10 Posts 3 Posters 138 Views 3 Watching
  • ATha1A Offline
    ATha1A Offline
    ATha1
    Hi folks,
    I'm sorry for asking, but I'm totally new to mysensors and home assistent, but I've already read a lot and watched youtube videos but in fact I'm right now not aware what I should do next.
    First of all, my setup is home assistent running on a raspberry pi 4 Model B. I've installed MySensors Libarary 2.3.2 and used the SerialGateway Sketch with some modifications to add a motion sensor directly on the Gateway to test the functionality.
    This is what my code looks like on an arduino nano:
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    //#define MY_BAUD_RATE 38400
    #define MY_BAUD_RATE 115200
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
      sendSketchInfo("Motion Sensor", "1.0");
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    In the configure.yml File I've added the following lines as described here:
    # Example configuration.yaml entry
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          baud_rate: 115200
    #      baud_rate: 38400
          nodes:
            1:
      persistence: true
      version: 2.0
    At the moment I get the following message:
    Unable to connect to /dev/ttyUSB0
    But as I connect the gateway it I can see, that /dev/ttyUSB0 should be correct.
    Any ideas?
    • bgunnarbB Offline
      bgunnarbB Offline
      bgunnarb
      I'm not very good with HA but in the GW sketch, to me it seems that you test if the Arduino is running on 8 MHz (#if F_CPU == 8000000L), which I guess it is not. So the #DEFINE MY_BAUD_RATE 115200 is never executed.
      So then the GW runs at what baud rate?
      Try to move the #DEFINE outside of the #if -- #endif and maybe set a lower baud rate, also in the HA .yml
      I have never been so busy since I retired!
      ATha1A 1 Reply Last reply
      • bgunnarbB bgunnarb
        ATha1A Offline
        ATha1A Offline
        ATha1
        @bgunnarb
        Thank you for that hint. I've actually used the default code and just copied the code of motion sensor at the specific functions including all the defines.
        Anyway, I still get the message:
        Gateway /dev/ttyUSB0 not ready after 15.0 secs so continuing with setup
        • ATha1A ATha1
          @bgunnarb
          @ATha1 I have not used Home Assistant myself, but this part of the installation instructions might be relevant:
          If you are using an original Arduino as a serial gateway, the port will be named ttyACM*. The exact number can be determined with the command shown below.
          ls /dev/ttyACM*
            ls /dev/ttyACM*
            ATha1A Offline
            ATha1A Offline
            ATha1
            @mfalkvidd
            Thank you for your reply.
            I’ve seen this but I couldn’t find any device under /dev/ttyACM*
            But I found /dev/ttyUSB0
            • ATha1A ATha1
              @mfalkvidd
              @ATha1 ok. Does USB0 disappear when you disconnect the Arduino? If it does, you can be pretty sure you've got the right name.
              It could be a permission problem. The instructions at the "Component could not be set up" section at the end of https://www.home-assistant.io/docs/z-wave/installation/ looks like the same stuff that is often needed for usb devices.
                ATha1A Offline
                ATha1A Offline
                ATha1
                @mfalkvidd
                Yes /dev/ttyUSB0 disappiers as I unplug the Arduino Nano Gateway and comes back when I connect it to USB again. So far so good, USB0 should be fine.
                When I do
                ls -l /dev/ttyUSB0
                it shows something equal to the link you gave.
                So owner 'root', group 'dialout'
                Most of the shell commands aren't available, for example no sudo, however I'm root, but also no usermod .
                Here is what the log-file said:
                2020-03-21 19:26:10 ERROR (MainThread) [mysensors] read failed: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
                2020-03-21 19:26:10 ERROR (MainThread) [mysensors.gateway_serial] Unable to connect to /dev/ttyUSB0
                • ATha1A ATha1
                  @mfalkvidd
                  When I do
                  ls -l /dev/ttyUSB0
                  @ATha1 nice work. I'm out of ideas unfortunately. Hopefully someone with HA experience is able to help.
                    ATha1A Offline
                    ATha1A Offline
                    ATha1
                    @mfalkvidd
                    I've enabled debugging:
                    1d2840de-1652-47ea-9636-eb896e60502d-image.png ![alt text](image url)
                    I've got this also on my Serial Monitor within the Arduino IDE. Is there the problem maybe somewhere else?
                    • ATha1A Offline
                      ATha1A Offline
                      ATha1
                      OK I found the reason.
                      I had to disable MY_RADIO_RF24 and MY_RF24_PA_LEVEL
                      so I commented out line 44 and 51 and it worked.
                      Sketch code:
                      * The ArduinoGateway prints data received from sensors on the serial link.
                      * The gateway accepts input on serial which will be sent out on radio network.
                      * The GW code is designed for Arduino Nano 328p / 16MHz
                      * Wire connections (OPTIONAL):
                      * - Inclusion button should be connected between digital pin 3 and GND
                      * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                      * LEDs (OPTIONAL):
                      * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                      * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                      * - ERR (red) - fast blink on error during transmission error or receive crc error
                      //#define MY_RADIO_RF24
                      //#if F_CPU == 8000000L
                      //#define MY_BAUD_RATE 115200
                      //#endif
                      I've also changed some lines in my configuration.yml
                      mysensors:
                        gateways:
                            persistence_file: 'mysensors/mysensors.json'
                            baud_rate: 38400
                        persistence: true
                        version: '2.3.2'
                      And the motion sensor showed up as Motion Sensor
